Zum Hauptinhalt wechseln
The Logitech Dual Action is a USB, PC controller for gaming. Model number: G-UF13A.
17 Fragen Alle anzeigen
Logitech Gamepad F310 connects/disconnects
Hi guys, I have this Gamepad or Joystick which doesn't work properly anymore. At first as I connected it to the PC told me that this last couldn't recognize the device so I started to teardown the gamepad thinking that the cable had problems. After desolder and resolder the wires to the PCB I connected it and now the controller shows a kind of loss of power two seconds after being plugged. I measured it with a multimeter trying the vary combinations pointing it to make contact with the pins inside the USB socket and the other end of the cable, of course with the all wires exposed, and I noticed the multimeter gives me a resistance of about 450 ohm when I check the red wire and - D- D+ (minus, data- and data+). Ps: when the cable is completely disconnected from the device the multimeter doesn't show me any resistance.. Now can anyone explain me something about electronics and maybe help me to find out the issue? I thank a lot everybody in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Cut the end of the usb cable, approx. 5 cm and resolder it. It should work.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Fabri wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 42
Insgesamt: 2,205
