Zum Hauptinhalt wechseln
The Toshiba Satellite M45 Laptop is designed for powerful, portable, multimedia computing. It features a 15.4” WXGA Display running Microsoft Windows XP, with 1.6GHz Processor, 512MB RAM, and 80GB Hard Drive.
13 Fragen Alle anzeigen
Toshiba Satellite M45 exhibits strange power/POST behavior.
Got this one handed to me in a dormant state - laptop hadn't been powered up in a while. Charged the battery for 15 minutes, and proceeded to restore the hard drive to its factory state using the recovery DVD (for the first time - I had to break the case seal to use it).
During the first powerup for Windows, the laptop locks up when prompting for a user name. Subsequent attempts to power down and up resulted in freezing at the Toshiba splash screen. There was one 512MB memory chip and I changed its memory slot and changed the chip entirely. There was no change in behavior.
I cleaned the heatsink, reseated the CPU, and replaced the hardened grease with Arctic Silver 5. I removed the mPCI WiFi card. I removed the battery and used AC power.
MHDD 4.6 essentially tested the hard drive to be good. There weren't any sectors that were bad, but there was a pattern of slower sectors towards the end of the drive. I also reseated the hard drive.
I flashed the BIOS from 1.70 to 2.00
I'm still getting lockups ... BUT ...
... they go away when I slap the laptop on the keyboard area. I have yet to slap the underside, but I'll probably start doing that instead ...
... unless I can figure out whether there's a link between what I'm seeing and a possible issue with a bad ground on the motherboard.
Any thoughts?
Thanks for reading!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try replacing the BIOS battery--it could be when slapping the keyboard you are getting a temporary improvement on a weak battery connection. The computer is 6 years old and if the battery has not been replaced it could be getting tired especially since it wasn't powered up for some time.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
lkvee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 825
