Zum Hauptinhalt wechseln
The Motorola Razr V3, also known as the Motorazr V3, was the first Razr released into the market in the third quarter of 2004.
22 Fragen Alle anzeigen
Razr v3 Wont charge
I recently flashed my razr v3 and now it doesn't charge it says unable to charge. It still works when its plugged in but when I unplug it it turns off. Not sure if it's the batterys fault or the phone's.
Edit: The battery outputs 1.91v on the 2 outside terminals and the 2 inside ones output 0.02v. the phone outputs 2.10v. It still wont charge
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
could I directly put 3.7 volts to the 2 inside battery leads or will it explode?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Panayiotis Michalos  this “The battery outputs 1.91v on the 2 outside terminals and the 2 inside ones output 0.02v. the phone outputs 2.10v.” sounds like your battery is discharged below the threshold of taking a new charge. Start off by replacing the battery and then re-evaluate. If nothing else it will give you a known-well starting point should further troubleshooting become necessary.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Panayiotis Michalos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 39
Insgesamt: 2,829
