Zum Hauptinhalt wechseln
Originally released in 2006, the NeatDesk is a desktop document scanner with ADF and full-duplex features. The early revision has model number "ADF-070108" and the newer revision is model "ND-1000."
37 Fragen Alle anzeigen
Scanner just went out
My neat scanner just went dead. Unplugged and plugged it in again; even plugged it into another outlet. Is there a reset button? Can it be fixed or is it not worth it? We had a power outage and when the power came back on it wouldn’t work. Could a power surge have burned out the power source in the scanner?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi,
If possible, it is always worthwhile to at least attempt to repair anything.
Not only is there the satisfaction of having done so, if successful, it means that in this case for a while at least it won’t add to the ever growing mountains of e-waste.
The resultant power surge that may have occurred when the power was reconnected after the outage could have burnt out components in the scanner,
Here’s a link to the ifixit NeatDesk™ Desktop Scanner Circuit Board Repair guide. This should be of some help in opening the scanner to initially do a visual inspection to see if there is any obvious electrical damage to the electronic components, such as burnt out surge suppressors, blown capacitors and blown fuses etc.
If you do see something (or even if you don’t) and are unsure, take some close up pictures of the circuit board and post them back here.
Here’s how to do this.
Bilder zu einer vorhandenen Frage hinzufügen
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
NeatDesk™ Desktop Scanner Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 hour
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Eileen Halverson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 216
