Zum Hauptinhalt wechseln
The Olympus Stylus 1010 is a 10.1 MP digital camera with 7x optical dual image stabilized zoom. It has a 14.7 MB XD-Picture Card. The camera is 99 x 56 x 25 mm and weighs 136 grams.
7 Fragen Alle anzeigen
My lens is stuck.
I've tested the battery and it is fine. I've removed the memory card and held down the function button while turning the camera on. This hasn't solved the problem - the lens is still stuck. What else can I try?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
من احتیاج به یک شارژر و یک باتری دارم برای دور بینم! باید چکار کنم؟
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Irene Rosko, take a look at this blog. It does describe in detail how to deal with this very common error. Should any of those steps not clear up the problem, then I would think that your issue is related to the IC that controls image processing. If it has failed you will have to replace that. But try the less invasive suggestion first. Good Luck.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
My. Camera is a sz1114 megapixel
Olyumpus 20x wide
von
Antwort hinzufügen
Irene Rosko wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 33
Insgesamt: 11,993
