Zum Hauptinhalt wechseln
Mittelstands Smartphone von Samsung. Gute Leistung für gutes Geld. Modelnummer: SM-A530F
23 Fragen Alle anzeigen
My phone will charge when connected to a laptop but not to any charger
It will spam the moisture in the charging port sometimes or just not register the wall charger at all. But as soon as I plug it into my laptop while turned off it will charge just fine.
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare
My phone does not recognise the wall charger. But the moment i plug it into a laptop for a second then replug into the wall charger it starts charging
von
same problem with me… 2 days ago mobile lower potion was exposed to water… not it is not charging with charger but charging with laptop. please tell me solution?
von
I am experiencing the same issue. How do I fix this? My phone only charges from the laptop...not the wall.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
There’s a chance that your media transfer only option is enabled. You should be able to swipe down from the top and see what method it’s using to connect via USB. Plug it into your computer and check, and change it to USB mode only if possible.
Hope this helps,
Austin
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
thank you so much, i switched to charging-only option for USB and it's charging again!
von
how do I find this?
von
Do a software update.... that may solve the problem
Bewertung 0
Antwort hinzufügen
Jonathan Onuluk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 30
Letzte 30 Tage: 205
Insgesamt: 26,235
