Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
Not recognizing new hard drive
When I tried to installed MAC OS 10.5. the system does not seeing the new drive and when I goes to utilities, still not seeing the new drive. ALl it see is just the DVD and nothing else. What I do I need to do...HElp
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Use Disk Utilities on your system installation disk and format the drive before trying to install a system.
UPDATE - Problem Solved
The new SATA drives need to be jumpered. I placed a jumper on pins 5 - 6, setting it to 1.5 GB. The drive came right up
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Actually I'm having the same problem right now. I'm trying to format a 1 TB Western Digital Caviar Black. I've tried it in a 20" 2.0 G5 iMac and a PowerMac dual 2.0 and the 10.4 system disk is not seeing it in Disk Utilities, this is the second HD in two days, I returned the first as DOA. Will try 10.5 next. Any ideas?
von
+ Apple EFI doesn't like SATA 3GBs drives. I am perplexed by this. More so, after I learned it is due to driver extensions.
von
If Disk Utilities doesn't see your new HDD check the wiring. If still out of luck try the disk externally or in a different Mac and try to format it there. Remember, on a PowerPC based machine you'll need to format it with the Apple Partition Table as opposite to the GUID table on Intel based machines.
Bewertung 2
1 Kommentar:
Wiring look ok. Tried external and able to partion it to apple partition but when I tried to installed the 10.5 MAC OS to the external HDD I m still unable to complete the installation.
von
Antwort hinzufügen
traudien wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 5,460
