Zum Hauptinhalt wechseln
Isuzu introduced the five-door Isuzu Rodeo to the United States in 1990 for the 1991 model year.
4 Fragen Alle anzeigen
Why cant I go over 50 mph?
I have a 94 rodeo. changed plugs wires filters etc. exhaust is broke and i have no power. it wont go over 50 and i crawl up hill. was told catalytic converter. my question is do i buy new one and fix exhaust or just bore out the old one?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Unbolt the exhaust pipe prior to the convertor and see if you gain more power. Does your state have emissions testing? Do you have an oxygen sensor after the convertor? If either question is YES then I don’t recommend to hollow it out, I also don’t recommend an aftermarket part as they normally don’t work properly to pass emission tests. I would not have a problem with a used exhaust system from an original vehicle at the junk yard, I would look at the oil first for normal maintenance from the old owner, engines that burn oil are not good candidates for a used exhaust system.
If you don’t gain power with an open exhaust then a weak fuel pump (low output volume) or bad timing (jumped belt by even 1 tooth) would be the next place to inspect.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
lyle_barrett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 27
Insgesamt: 272
