Zum Hauptinhalt wechseln
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
4 Fragen Alle anzeigen
The brush rotates intermitantly, seems as if there is a loose wire
The suction is fine but, the roller brush rotates intermittently. It re-engages when I bounce the LiNX but not always when I turn it on and off. There seems to be a loose wire or connection somewhere. Any suggestions will be most welcome.
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
I had a similar problem. However, my wire was severed. I had to open up the head unit and resolder it back together. Since that fix I have not had any issues.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Was the problem intermitent? Weems a severed wire would make it not work at all?
von
Yes mine works intermittent too, not sure what is causing this.
von
Antwort hinzufügen
Alan McDonald wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 483
