Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
Boots from PRO 860, but fails when I update the OS.
Customer brought in a Power Mac G5 with a failed HD, and for reasons decided to upgrade to an SSD. I put an Samsung PRO 860 inside, booted from a Leopard DVD, formatted the drive, and installed Leopard. No issues, and everything works fine. I then ran software update and it downloaded two updates, 10.5.8 and (I think) iTunes. When it restarted, it couldn’t find a bootable volume any more.
If I boot from the Leopard DVD it sees the volume as having 10.5.8 installed on it, and Startup Disk sees it as a viable boot volume. Holding OPTION at startup shows no bootable volumes (assuming the Leopard DVD has been removed).
I thought it might have been a bad install so I tried again with the same results: Under 10.5 it works fine, but after Software Update it breaks.
Some Googling around revealed that disabling TRIM may solve the issue so I removed the drive, put it in a PC, used Samsung Magician to disable TRIM (reformatting it in the process), put it back in the Mac, and tried again with the same results.
I tried it in both drive bays, same results.
Why can’t I boot this drive?
UPDATE: If I install 10.5, then update to 10.5.8, on a traditional spinning HD, then clone the resulting system to the SSD, the SSD boots and works normally. So it’s something to do with the update process itself that’s causing the issue.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sounds like you didn’t format the drive to the correct low level format. The G series use an older format type than what the Intel systems use (GUID/HFS+).
You also need a SSD which supports SATA I (1.5 Gb/s) unless the spec sheet calls it out the drive won’t work! Luckily the Samsung 860 EVO is one of the few that should work.
Apple never validated SSD’s with the older OX-X’s, El Capitan is the first release Apple offered TRIM support for 3rd party drives which doesn’t help you.
You’ll need Cindori’s Trim Enabler for the OS-X Leopard. I’m not sure if they offer a compatible version for the G series version OS’s.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
If I formatted the drive wrong, I wouldn't have been able to boot into 10.5. But I can. Unless you're suggesting the drive format changed during the 10.5.8 update process?
The PRO 860 does support SATA I.
I've disabled TRIM on the PRO 860 so that's not an issue. (Trim Enabler is Intel-only so that wouldn't help anyway.)
von
Antwort hinzufügen
Steve wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 85
