Zum Hauptinhalt wechseln
Das erste Modell des iPhone, Modell A1203 mit 4, 8 oder 16 GB Kapazität und einer Aluminiumrückseite. Die Reparatur erfordert erhebliches Hebeln und möglicherweise auch Löten. Diese Seite soll Nutzer:innen bei der Fehlersuche und -behebung helfen und sie bei der Suche nach Hilfe für das iPhone 2G unterstützen.
224 Fragen Alle anzeigen
Which of the three Mainboard-Connectors is for the Touch-Sensor?
After disassembling my 8 gig 1st Gen iPhone in order to replace the broken glass and digitizer I found my Touch-Sensor not working anymore.
So I redid the whole procedure and it worked without a glitch, for about 3 hours...
Since everything besides the touch-recognition works I think it might be a faulty connection from the digitzier to the logicboard.
Does anybody know which one of the mainboard-connectors is responsible for what task? I named the connectors as follows ;)
  • the one on the side of dock-connector (with the black clamp)
  • the really annoying small one on the camera-side
  • the bigger one on the side of the camera.
Thank you very much for your help!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
+1 for a well written question
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I Believe that in this photo, it is the cable on the top-right:
http://s1.guide-images.ifixit.com/igi/DF...
War diese Antwort hilfreich?
Bewertung 3
So, when u open the iphone, to take the touchscreen out, you gotta disconect one cable, by sliding it out, then another by pushing and another one by pushing too... your problem is in the number two! i fixed my iphone and in the end, the touchscreen wasn´t responding... the conector number one was good, the number two was loose and the number three was ok... so i pushed the number two conector and it made a "click" sound.... then it came back to work...
Bewertung 0
Antwort hinzufügen
tokyo2ooo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 11,767
