How to fix E:61:10 flashing error in my Sony FDR-AX33
E:61:10 flashing error in my Sony FDR-AX33 I dropped it once.
Ist dies eine gute Frage?
Georgio7564044 Error code E: 61: 10 possible cause for that is an Issue of the zoom driving part. This usually requires a new lens since parts for the internal workings are most often not available. You can always try what is shown here.
War diese Antwort hilfreich?
I found the solution from trial and error while I was attempting to fix my camera. There’s a tiny circuit board with a chip attached to a ribbon and red and black cables on the right side (from your perspective facing the viewfinder/eyepiece) of the camera when the shell is disassembled. I’m assuming that’s an accelerometer or other sub-processor for BOSS. Remove it and reseat it to reset the chip.
The one just above the headphone output and mic input?
Letzte 24 Stunden: 2
Letzte 7 Tage: 33
Letzte 30 Tage: 153
Insgesamt: 5,614
1 Kommentar
If I need to replace the steady shot assembly, where can I get this fix near me in Mansfield, Ohio. and can i fix it, or replace it myself.
von georgio7564044
