Zum Hauptinhalt wechseln
Valve Steam Controller, veröffentlicht am 10. November 2015. Modell 1001.
21 Fragen Alle anzeigen
My t6 bit got stuck
I was tearing down my steam controller to use its trackpad because my trackpad on the vive’s controller doesn’t vibrate. When I was tearing it down I went to take out the screws on the side, not knowing the bit wasn’t long enough (t6). It got stuck and I couldn’t get it out I even drilled around it to see if I could get it loose, unfortunately, the bits stuck and I can’t get it out. My brother own’s the iFixit kit I used, so I didn’t buy it.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
I had almost the exact same issue with my recent tear down, those are VERY recessed.
I was able to pull mine out with my side cutters as the bit was just long enough to grip in my case.
Looks like you may need to Dremel beside the bit a little so you can get a grip on the bit with something like I did.
It is mostly hollow void behind the back of the controller and the chutes the screws go into aren’t touching anything until you reach their full depth.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jake Gardner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 29
Insgesamt: 350
