Zum Hauptinhalt wechseln
Released in 1999, the Braun Exact Power EP100 is an electric beard and mustache trimmer. It has an internal rechargeable battery.
3 Fragen Alle anzeigen
hair trimmer cut hair very short period, WANT TO CHANGE BATTERY
Type and capacity of battery to braun ep100
What volt
What watt
What mah
update
Great thanks for all who help me
update
Please if possible
Answer on one more question
Very important!!!
What capacity of battery must be in broun ep 100, there is 1 battery, but
What capacity?
500 mah or 1000 mha
Very important
Great thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
One of the clearest and most direct questions I've seen asked on Answers in my time here.
von
The higher the maH the longer it will last on a single charge.
von
the person who wrote the how to guide also said he used a higher mAh battery and his charger didn't last so long. something worth considering
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
http://forum.eserviceinfo.com/viewtopic.... I found this link to how to get to the battery (page 2)but couldn't find what exact battery was in your trimmer. You will be able to find that by taking the trimmer apart and then matching it up after. good luck
War diese Antwort hilfreich?
Bewertung 7
2 Kommentare:
+ for finding out how to change it
von
Yes indeed--I looked for some time with no luck. +
von
That wasn't easy to find but you need - (3 AA-size, 1.5V)
http://www.braun.com/global/male-groomin...
I'd also get a battery charger and rechargeable batteries like this one: http://www.google.com/products/catalog?c...
Bewertung 5
3 Kommentare:
Good research on your part also. +
von
Only the EP 15 and Allstyle use the 3 AA size batteries. the Battery on the EP 100 is soldered to the logic board
von
Very good OT, I missed that.
von
Well here is a replacement R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm Fits Braun Models: Action Line, EP50, EP60, EP80, EP100, 540, 570 from here http://www.electricshaverstore.com/get_i... and here is the service documentation. The EP100 actually is a Braun 5601
Bewertung 3
3 Kommentare:
+ nice searching
von
+ You have a plethora of resources.
von
;-) Could not fix some of my old "stuff" without those resources. I actually purchase and repair according to the manuals I can get, makes my hobby easier.
von
Antwort hinzufügen
IGOR wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 22
Insgesamt: 6,382
