Car stuck in limp mode..accelerator is not responding..changed accele.
Stuck in limp mode..accelerator does nothing..changed accelerator but same thing
Ist dies eine gute Frage?
You need to find the fault codes and that will give you a idea what you need to physically check. So this has a throttle sensor and you changed it and it didn't do anything. You need to test each sensor for input voltage and output voltage from the sensor to the ecm/pcm. You could have a mouse that chewed a wire. You need to find the flow chart for the trouble codes and follow them. Repairing automotive computer systems is not easy. It takes a lot of education and skill and thousands of dollars of equipment. My advice is if you aren't a trained automotive technician who specializes in diagnostic repair and has spent thousands of dollars on equipment, I would recommend taking it to a repair shop. You will probably pay more money throwing parts at it and not fixing it.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 183
