Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
Where is the memory conroller heatsink located on early 2005 power mac
I have an early 2005 Powermac G5 dual processor 2.3 with 2GB of memory. I recently started this up and have been playing around using OSX 10.4.11. I downloaded a program that shows me the temps inside. I’m sitting idle. The temps seem kind of high. Both processors are around 53 to 57 C which might need the thremal paste redone. However, the concerning temp is the memory controller heatsink that’s reading 73 C.
If this is normal for this machine or if it might just need a dusting that’s one thing. But I don’t even know where this is located on the board. Any guidance is helpful. I plan on tearing this thing down soon and giving it a through cleaning, but if there’s any places I should focus on I will.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
So I will throw an answer here in case someone comes across this with a similar issue.
I should've wrote this when it was still fresh in my mind. However, the memory controller chip is on the back side of the logic board. YAY! You have to completely disassemble the Powermac and remove the logic board. I think there was either a separate fan for the memory controller, or one of the main case fans had a vent that went to the back.
The heatsink is held on by black plastic push pins that will break very easily. I don''t remember if I had modified new pushpins from Amazon, or if I had gone the nylon bolt route. If you get the push pins off of Amazon or a similar place, you have to use a razor to trim the wings to a similar size that Apple has in there and it should work. Good luck!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Michael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 60
