Zum Hauptinhalt wechseln
Repair guides and support for the third generation Dodge Dakota (2005-2011). The redesigned 2005 Dakota shared its platform with the new Dodge Durango SUV (which is now similar to the Ram platform).
18 Fragen Alle anzeigen
What are the required fluids and capacities for a 2005 Dakota 3.7L 4wd
I'm having trouble finding the fluid capacities and their requirements for my 05 Dakota 3.7L 4wd. All I've come across in several searches is the pdf from Dodge, but it has their part numbers instead of sae grading.
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@jcewl93 Fluids and Capacities are as follows
Fuel
3.7L/4.7L, 87 Octane 22 Gal.
Engine Oil (with filter)
3.7L, SAE 5W-30, API Certified 5 Qt.
Cooling System (includes 2.1 Qts./2L for coolant bottle 3.7L (Mopar Antifreeze/Coolant 5 Year/100,000 Mile Formula) 13.3 Qt.
The total fill requirement for the four-speed automatic transmission is 8.8 qts., and 17 qts. with the five-speed unit.
Automatic Transmission Mopar ATF+4, Automatic Transmission Fluid.
Manual Transmission (Getrag 238) Mopar ATF+4, Automatic Transmission Fluid.
Transfer Case Mopar ATF+4, Automatic Transmission Fluid.
Front Axle SAE 75W-90 Multipurpose Type, GL-5 Gear Lubricant (MS9763).
Rear Axle SAE 75W-140 Synthetic Gear Lubricant (MS-8985). Limited-slip rear axles require Mopar limited-slip additive (MS-10111). Four ounces (118 ml) should be added to the gear lubricant whenever a fluid change is made.
Brake Master Cylinder Mopar DOT 3 and SAE J1703 should be used. If DOT 3 brake fluid is not available, then DOT 4 is acceptable. Use only recommended brake fluids.
Power Steering Reservoir Mopar ATF+4, Automatic Transmission Fluid.
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
Jeff Espey wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 33
Letzte 30 Tage: 204
Insgesamt: 10,180
