Zum Hauptinhalt wechseln
Mit Satellitenradios kannst du bestimmte Sender rund um die Welt empfangen.
25 Fragen Alle anzeigen
Docking station works fine in one building,
Two buildings 20 yards apart. Two radios with docking stations work fine in bldg. A, neither one works in bldg. B. Both buildings have outdoor antenna with same view of the sky. LCD display shows station, artist and song title but no audio. Radio in bldg. B worked for about 5 years then quit. Replaced antenna and wiring in bldg. B still not working.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi @mcjimbo ,
Don't know the system that you're describing but are the docking stations fixed to the radio or are they fixed in the building and the radio can be removed so to speak?
If fixed in the building, just wondering if you can swap the docking stations to eliminate it as a possible cause.
von
Einen Kommentar hinzufügen
1 Antwort
Turns out the problem is with the power unit. It is a switching adapter that powers the speakers along with the radio function. Not sure exactly how it works but it can power the unit without powering the speakers. I have a new one on order, will update when it is received.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jimbo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 71
