Zum Hauptinhalt wechseln
Die Reparaturen reichen vom Flicken eines Lochs bis zum Auswechseln eines Reißverschlusses bei Hosen von Patagonia.
28 Fragen Alle anzeigen
Best way to replace the elastic waistband in Patagonia Baggies shorts?
I have a pair of green Patagonia baggies that are about 10 years old — they’re super comfy, totally functional, and still look fantastic. Unfortunately, the elastic waistband is completely shot, so the drawstring is the only thing keeping them up. I’m not ready to retire them yet, so is it possible to replace the elastic in that waistband?
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
My boxer shorts have same issue...only no draw string.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi Guv!
It is entirely possible to replace the waistband. If you’re looking to do it yourself, you will want to purchase one inch sewing elastic with drawstring. You’ll remove all the seams encasing the elastic and measure your desired waistband. It can be helpful to measure a pair that you like the fit on. Cut the elastic and sew it back into the shorts. If you’re searching for another option, most local tailors should be able to perform this repair!
Patagonia does not repair baggies as they are considered next to skin garments.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Guv Callahan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 52
Insgesamt: 1,811
