Zum Hauptinhalt wechseln
The Logitech Dual Action is a USB, PC controller for gaming. Model number: G-UF13A.
17 Fragen Alle anzeigen
My controller keeps disconnecting
So basically, I’ve been trying to play games with my controller, and it only SOMETIMES connects, and if it does it’s only for a split second, I think it might be because a bit of the special uhh, whats it called? protective case of the wires is exposed, like the white stuff, it’s from the Kittens I have.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi Joshua!
Basically it means that you need to replace the cable. I would replace it first and see how that goes.
Just get the glue off and de-solder the cable. Make photo’s before you proceed as you need to know which color goes where. It will not be easy to find the cable (part).
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Sorry but that doesn't help much, I have no idea how to do these things, I think I might take it to my step-brother, he knows how to do these things I think, he is currently replacing the loose battery on my 3DS, so Ill ask him about this and see if he can help me.
von
Hi Joshua! Sry for the late reply.. Yes you can ask him to replace it if he is able to find the part.
von
Antwort hinzufügen
Joshua Durbidge wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 590
