Zum Hauptinhalt wechseln
The RIDGID R84015 X2 is an 18v, 1/2 inch chuck, cordless drill.
6 Fragen Alle anzeigen
Chuck is stuck and will not turn
I went to use my drill the other day and when I went to put a bit in the teeth, the chuck would not move. I could not get the teeth to move at all, and the chuck would not turn. I thought maybe it was just stuck and thought about putting something in there to loosen things up, but my father-in-law was afraid it might get into the electrical parts. Any information on how to get this unstuck would be helpful. Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
2 Kommentare
This is a notorious problem, (you'd think RIDGID would have something on their website) but the solution is to slightly turn the rear collar to open then put a 7/8" wrench on the shaft behind the collar and finally, carefully turn the chuck CCW with a pair of pump pliers avoiding scoring it.
von
Doug.. GREAT... Did as you described and was able to open and close the chuck jaws.. so I can get a bit in and out.. Won't be needing to do much drilling so your help save me a bunch of $$$....
Thank you
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Matt, on your chuck the rotary action of the outer body which acts on an internal screw; this in turn moves the threaded jaws in or out along a tapered surface. So, if any of the jaws, has jumped the thread, it will create a wedge and stop the chuck from moving. You can try to hold the drill with the chuck down and gently tap it with a small hammer (or the handle of a screw driver :-) and see if it will free the jaw. Otherwise, I would think it is time to replace the chuck. It is held on by a bolt right in the middle of the chuck. No electric parts are directly involved with this. Replacement parts and a diagram are available right here. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 6
3 Kommentare:
That worked. Thanks for the simple fix.
von
I had no idea how to get it to move.
I turned it down, several taps with a small hammer.
Round she goes. Yay! Thank you!
von
On my Ridgid #5010 hammer drill, there is a small hole like where a chuck key would fit. I lubed it several times with a penetrant/lube (3 in One, first, then dome Red-Armor from Ace hardware) and it worked for me!
von
I have the same B&D mains! What happens to these chucks is the end up with dust from drilling masonry! Never try to Grease the chuck. use and releasing fluid WD 40 or generic. Spray down inside the chuck. Place a spanner on the the nut at the the back of the chuck , it requires a standard open Jaw spanner I used a 3/4 Af. Take circular wrench and hold it on the outer side on the chuck and gently turn counter clockwise! Chuck to you right spanner on the base of the chuck and turn the out case of the chuck away from you gently! Then give it regular clean with releasing fluid!
Regards. Fred.
Bewertung 1
1 Kommentar:
This worked. Thank you and WD-40!
von
Take it back to the store Rigid tools have lifetime guarantee
Bewertung 0
1 Kommentar:
life of tool only I recently had them not honor warranty on 3+ year old cordless drill with a frozen chuck
von
Removing and installing r5010. 1001
Bewertung 0
Antwort hinzufügen
Matt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 86
Letzte 30 Tage: 332
Insgesamt: 96,135
