Zum Hauptinhalt wechseln
Reparaturanleitungen für Rollei Kameras und Zubehör.
4 Fragen Alle anzeigen
How to clean the matt screen of a Rolleicord II?
I own an old Rolleicord II. It's matt screen is quite dirty, so I'd like to clean it. Can anyone help me how to do so?
My first approach would be to disassemble the camera until I can remove the matt screen, then clean it with isopropyl and a cotton stick. Is that sound?
Are there any problematic steps when disassembling, I have to be aware of?
Thanks in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Is the inside of the screen dirty? You could take the camera apart though there are some risks to doing that. Firstly, I’d recommend grounding yourself and your work surface so as to be sure you don’t damage the camera with static. iFixit makes a great kit for grounding your workspace and yourself: Portable Anti-Static Mat
For the actual cleaning, isopropyl  should do the job, but be sure to let it fully dry before you reassemble the camera. A screen or optics cleaner could work too
Portable Anti-Static Mat Bild
Produkt
$29.95
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I don't think grounding has any effect here, as there are no electronics in this old camera.
von
Hello, I suggest you do the cleaning itself not with isopropyl, but with ECLIPSE Optic Cleaning Fluid by Photosol Inc. (you can also use cleaning pads sold by them, recommended). Isopropyl will leave the traces. Clean everything you can with a soft brush, then finish with the fluid. That way, you will have your screen as clean as it was when it left the factory.
Bewertung 0
1 Kommentar:
Thanks, this cleaning fluid looks good in general.
Not sure thou, if this old matt screen is already coated, i.e., if its necessary to use a special fluid for cleaning?
von
For cleaning the matt screen, see the other answers.
Unmounting the matt screen
Simply screw off the following four screws:
Now, the frame holding the matt screen can be pulled out:
Bewertung 0
Antwort hinzufügen
Friedrich Wiemer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 274
