Zum Hauptinhalt wechseln
Repair guides and support for cash registers.
54 Fragen Alle anzeigen
G800 SD electronic cash register
Hi how are u hope ur fine, ,may kind assist me with my G-800 SD electronic cash register,, the upper black button that use 3 keys is missing ,the one that is used to control the use of the cash machine I don't know how i missed it ,and the machine is still brand new never 4been used before, may you kindly help me with replacing that button and please assist me with giving me giving me the user manual again I misplaced it. thanks you
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
You can get the manual for this cash register at https://data2.manualslib.com/pdf4/88/872...
von
Einen Kommentar hinzufügen
1 Antwort
https://www.manualslib.com/manual/872656...
here is a search for repair places. you can call and order what you need but there really isn’t much online as these are basically a closed parts system like ATMs are.
https://www.google.com/search?q=nts+cash...
however if you are referring to the keys that unlock it for use than you can also get them from these places but you will need the serial and model numbers off the register. usually these are a stick on the underside of the unit.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Eva Mogale wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 232
