Zum Hauptinhalt wechseln
The Olympus OM-D E M10 Mark II is a 16 megapixel mirrorless camera that was introduced in 2015. This camera can interchange lenses with its easy to use platform that is both user friendly and priced for amateur photographers without lacking professional capabilities.
5 Fragen Alle anzeigen
Camera not powering on
Display was not working fine so I have replaced flex cable. Right now the camera is not powering on but there is a light on front that is flashing. I have also measured voltage on mother board across flex cable from display and I am reading 2.9v max. Do I have to replace the entire motherboard?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Why did you think the display needed replacing? Did you bang or get your camera wet?
von
The display was flashing during tilting
von
Einen Kommentar hinzufügen
1 Antwort
What happens if you disconnect the display cable from the logic board? Does the eyepiece display still work?
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Vitt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 308
