Zum Hauptinhalt wechseln
The first generation of the compact sport coupe, the Scion tC.
6 Fragen Alle anzeigen
Why is my RPM too high at lower speeds and car not shifting into third
Got a used engine under 55k mikes installed at auto shop due to a failed piston compression in my previous one. Get the car back a week later told it’s fine to drive. Come to find out that the RPM’s are way too high going a slower speeds. Took it in again and had them check the transmission and they installed a new filter and topped off fluid. Still having same issue but they told me that the car needs to relearn when to shift since but i drove it over 20 miles at various speeds and is doing the same thing. I told them to check the ECU but insisted that it just needed to relearn. What is the issue?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Save yourself time and headache and take it to a Toyota dealer\shop.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If it IS the ECU needing to relearn… check this website: https://autoguysland.com/how-long-does-i...
It has helpful information. 20 miles may not be enough for it to fully relearn everything. It can take a bit longer than one would think. If you still think something is definitely wrong then I'd advise taking to a dealership. It could be that your TCM needs flashed.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Christian Agullana wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 140
