Zum Hauptinhalt wechseln
FLIR FX is an HD security camera with wireless Wi-Fi monitoring by FLIR Secure.
4 Fragen Alle anzeigen
My surveillance project, I understand just enough to get in trouble
So the project I'm working on, I'm using 4 cameras, I have purchased a ZOSI H.265+ 5MP Lite CCTV DVR 8 Channel Full 1080p, it doesn't come with a hdd or camers, so I was going to purchase
Western Digital 4TB WD Purple Surveillance Internal Hard Drive HDD - 5400 RPM, SATA 6 Gb/s, 64 MB Cache, 3.5" - WD40PURZ
and
ZOSI 1080p Dome Security Cameras (Hybrid 4-in-1 HD-CVI/TVI/AHD/960H Analog CVBS),2MP Day Night Weatherproof Surveillance CCTV Camera Dome Outdoor/Indoor,Night Vision Up to 80FT
I just don't know if this will work, am I missing something? My knowledge level is probably a minus something out of 10, could really use help. Thank you everyone.
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
Oops sorry I meant to add,
Expense is an issue which is why the equipment isn't the most expensive
von
Einen Kommentar hinzufügen
1 Antwort
The only issue is the size of the HDD. I can't find any info on that but I have not seen 2.5" surveillance drives so it is a good assumption it takes a 3.5" drive. So, you should be good to go. Check your manual.
Since you are using the same mfg cameras, there should not be an issue with that.
Good luck.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Neil A Jones wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 137
