Zum Hauptinhalt wechseln
The sixth generation of the Subaru Legacy made its debut at the 2014 Chicago Auto Show, and went into production for the 2015 model year.
2 Fragen Alle anzeigen
check engine light on code p700.
i got this check engine light everytime it rains . i scan the code and it show p700 . ( transmission failure ) however the car run okay no problem and after 2 days of doing running the check engine light will turn off.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
See if the diagram here helps. It's from the Outback Owners site.
https://www.suoutback.com/transmission_h...
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It could be a number of issues but when you said it mainly happens when it rains then i would put money on it being a bad connection in the wiring harness to the transmission. Maybe water causing a short circuit & then once it’s dried out the transmission control unit thinks the fault has cleared.
I would follow the wiring harness from the left side of the dash, through to the gearbox. Checking for any breaks in insulation & also the security of any connector blocks outside of the interior of the vehicle. I know the Subaru Forester has 2 BIG connector blocks on the top of the gearbox around the bell housing area. It maybe the problem lies in those. Google your transmission wiring harness & see what the photos show you.
Good luck
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
EDWIN CHAN MENCIAS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 289
