Thermal Pad replacement thickness
Does anyone know the thickness of the thermal pads?
Ist dies eine gute Frage?
Unfortunately, I cannot find anything on the specific thickness of the thermal pad, but I did find an article on finding the best fit for your GPU. I'll link it here for your viewing, but I'll give you the spark-notes of it.
Ideally, you should use the thinnest thermal pad that you can with the device. Start with a 2mm thermal pad, and if it has an indentation from the heatsink go down a size of thickness. The material that you use also matters, as some materials dissipate heat better than others.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 21
Letzte 30 Tage: 98
Insgesamt: 4,058
