Zum Hauptinhalt wechseln
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
73 Fragen Alle anzeigen
Rough idling with p0345 code on the engine
I replaced the camshaft position sensor A bank 2 and the problem continues. The engine starts to idle very low and has cut out on me twice sense replacement of sensor. Battery and alternator is good. Not sure where to go from here
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
8 Kommentare
@fordlariat start of by reading this really great description of P0345 on here There is a lot more connected to the P0345 code then we assumed.
von
Wow there is a lot to process in that thread! I will have to reread all of that again when I sober up from that first go around. Thank you
von
So if my thinking is sound and that’s a big if!! My next thing to check, not replace lol, is the starter.
von
Some replies in vehicle forums can be misleading from anyone insisting their comments are correct above all others. Ever notice they're from owners and not experts in specific makes/models/years? Even trained dealer techs make mistakes. EFI systems can be either complicated or relatively easy depending on one's knowledge and experiences.
There's a great example of a repair shop on youtube finding and fixing a $1200 dealer repair that failed. Dealer threw parts at the repair and failed. This repair shop was referred to, systematically diagnosed then found..........a severely corroded engine ground falling apart that created mystery problems the dealer failed to diagnose. After replacing the ground cable, all problems disappeared, vehicle owner shared this repair and the dealer refunded costs, possibly from embarassment of the youtube exposing incompetence.
von
@notbroken absolutely. That is why any forum or any advice, always warrant a healthy does of caution. However, it is always good to consider work that others have done and maybe there is some validity on what was suggested.
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Ok so the final answer to this was that the plastic timing chain guide on the VTC was broken, on top of the phasers being broken as well. So they did a complete timing job replacing both phasers and VTC’s. The total damage was $2,200. The truck is back running like a champ! Thank you for all your support.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@fordlariat. Awesome and great that you got it on the road again. Not cheap but its going to pay you back quick.
von
@oldturkey03 your absolutely right on that. Now hopefully I have a while before any other major problems so that I can recoup lol.
von
Hilfreichste Antwort
Update: I took the truck to the base and hooked it up to a computer and they say it is my timing system ie: chain, phasers, guide rods and all.
Bewertung 1
2 Kommentare:
@fordlariat dang that is way off from the camshaft position sensor. Sorry to hear this and looks like you got quite a bit of work ahead of yourself.
von
You’re not lying! It’s a bit of work for sure and not sure what tangled web of things that my also need to be repaired at this point. So as much as it pains me to say it, I feel I would rather a professional repair it. My wallet will not like me for it but I think it may be beyond my scope of abilities. I will update with more information as it develops.
von
Antwort hinzufügen
Lariat f150 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 29
Letzte 30 Tage: 158
Insgesamt: 2,848
