Zum Hauptinhalt wechseln
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
1207 Fragen Alle anzeigen
PLEASE HELP!Attempting to fix my screen, lifting to inside of screen.
My screen got a crack in it. So I decided to replace it. When lifting the screen to get into the phone, instead of lifting ALL of it up, it is just lifting the display itself up... I don't want to be on the inside of the screen, rather the inside of the phone. PLEASE HELP!!!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Okay Joseph, calm down, it's okay.
First off, usually the reason the LCD separates from its frame is that you neglected to take out the Pentalobe screws securing the frame to the case. You did take them out, right? If not, do that now, before anything else.
Now, assuming you've got the LCD mostly off, you've got two choices. You can finish the job (you're replacing it anyway, right?) then tackle the frame that's still on the phone, or you can go back around the phone and make sure you're under the frame this time and free it all up that way.
This is what your phone will look like if you take the LCD off without the frame.
Versus the inside without the display frame.
You're not the first to run into this; here's another post from someone who had the exact same thing happen.
SOLVED: Why does the inside of my iPhone x look different than everyone elses? - iPhone X - iFixit
You'll be fine once you have the frame and the LCD off; nothing you're doing will damage the rest of the phone, only the old LCD that you're replacing anyway.
Let us know how it goes.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Joesph Dunne wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 243
