Why is my Hyper Tough 1.5 gallon shop vac making a loud roaring noise
It's roaring like it is stopped up but it has some suction. I've done EVERYTHING. How can I take the top apart?? I've tried cleaning filter and all.
Ist dies eine gute Frage?
Hi
If you vacuum is making a loud “roaring” noise it’s probably one of two things
1)something is loose inside
Or
2)something is loose or had worn out in the motor
Here’s a disassembly guide
Shop-Vac MC150A Motor Replacement
If you go as far as the motor ,pay close attention to the motor bearings and where they are seated,if they have any play in them they are most likely your issue
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
@charitymc08 have you removed the filter and checked the float? Post some good pictures of what that area looks like on your vacuum. Most tops on other shop-vacs are riveted whereas your model appears to have screws . Looks like you will need to remove those to remove the top.
After that I'd focus on screws 101 to remove the top toward the float etc. That is the area that I would focus on since debris there can create a blockage. We need to see more to try to help you further. Bilder zu einer vorhandenen Frage hinzufügen
Letzte 24 Stunden: 9
Letzte 7 Tage: 31
Letzte 30 Tage: 165
Insgesamt: 2,671
