Zum Hauptinhalt wechseln
The Hoover LiNX is a cordless vacuum cleaner. The vacuum uses interchangeable fade-free lithium-ion batteries that allows this device to be used everywhere and on multiple floor types. The Hoover LiNX uses Hoovers WindTunnel® 3 Technology which uses three channels for suction to suck up debris.
4 Fragen Alle anzeigen
turns on and quickly turns off
My Hoover LiNX coordless vac got caught on the end of a rug, did not catch anything in the blade, then turned off. When I turn it on again, after reviewing the rollers, etc, it turns on for quick second and then stops. Any idea what I can do to make my wonderful vac came back to life
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If your Hoover LiNX cordless vacuum cleaner is turning on and then quickly turning off, there may be a problem with the motor or the power supply. Here are some things you can try to troubleshoot the issue:
  1. Check the power supply: Make sure that the vacuum is fully charged and that the power cord is securely connected to the vacuum and to a working outlet.
  2. Clean the filters: Over time, the filters in your vacuum can become clogged with dust and debris, which can restrict the flow of air and cause the motor to overheat. Clean or replace the filters according to the manufacturer's instructions.
  3. Check for obstruction: Carefully inspect the vacuum for any obstructions that may be blocking the air flow, such as tangled hair or debris. Remove any obstructions and try turning on the vacuum again.
  4. Check for damage: If your vacuum hit something or was dropped, there may be damage to the motor or other internal components. Inspect the vacuum for any visible damage and contact the manufacturer for further assistance if needed.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
RoseMary Cummings wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 497
