Zum Hauptinhalt wechseln
Magnetischer AC-Netzadapter der 2. Generation für MacBook-Produkte, erstmals 2012 veröffentlicht. Nicht kompatibel mit Systemen der vorherigen Generation. Erhältlich in den Versionen 45 W, 60 W und 85 W.
26 Fragen Alle anzeigen
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
War diese Antwort hilfreich?
Bewertung 5
16 Kommentare:
So the output from both Power pins must be around 20V?
I have 85W charger.
von
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
von
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
von
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
von
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
von
11 weitere Kommentare anzeigen
Antwort hinzufügen
Yurii Chaikovskyi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 73
Letzte 30 Tage: 365
Insgesamt: 6,108
