fairphone ist nass geworden, bildschirm schwarz
fairphone fiel ins wasser - akku rausgenommen, über nacht in reis gelegt. erst funktioniert, anschliessend spielte bildschirm verrückt, danach nur noch schwarz.
Ist dies eine gute Frage?
@nicole67 Rice does not work. It does absolutely nothing to help you with this repair. All it does is waste time and waste food. Check here https://www.ifixit.com/News/30047/rice-i... for more on this.
The very first step I would take is to disassemble your Fairphone. Use these guides Fairphone 3 and 3+ to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors, etc,. Take a look at all the connectors as well as cable ends. You will have to remove all the EMI shields from the circuitboard. If you do not remove the shields, you are not cleaning the board. Once you get the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in higher concentrations will evaporate quickly and dissipate the water. The importance here is the cleaning. It would, of course, be best to get it professionally cleaned with an ultrasonic cleaner. After it is cleaned, do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that, reassemble your phone and re-evaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance of being fully repaired, but at least you can give it a try.
Translation
@nicole67 Der Reis funktioniert nicht. Es hilft dir absolut nicht bei dieser Reparatur. Er verschwendet nur Zeit und Lebensmittel. Hier https://www.ifixit.com/News/30047/rice-i... findest Du mehr dazu.
Der allererste Schritt, den ich machen würde, ist, dein Fairphone zu zerlegen. Verwende diese Anleitung Fairphone 3 and 3+, um dir beim Zerlegen deines Telefons zu helfen. Sieh dir alle Komponenten und Anschlüsse sorgfältig und genau an. Beurteile den Schaden genau. Suche nach starker Korrosion, untersuche die Stifte in den Anschlüssen usw. Sieh dir alle Anschlüsse sowie die Kabelenden an. Du wirst alle EMI-Abschirmungen von der Platine entfernen müssen. Wenn du die Abschirmungen nicht entfernst, reinigst du die Platine nicht. Sobald du die grobe Verschmutzung beseitigt hast, verwende 90 %+ Isopropylalkohol und reinige deine Teile noch etwas mehr. Für eine ordnungsgemäße Reinigung verwende [Anleitung|5825|diese Anleitung], die zwar für ein Apple iPhone 3G geschrieben wurde, aber auch für dein Telefon relevant ist. Ich kann gar nicht oft genug betonen, wie wichtig eine gute Reinigung ist, also führe sie immer wieder durch und ersetze den Alkohol nach jeder Reinigung. Verwende für die Reinigung keine Druckluft, da diese sowohl Flüssigkeit als auch Korrosionspartikel in Bereiche treiben kann, die später Probleme verursachen werden. Verwende kein Trinkwasser, wenn du Wasser verwenden musst, dann nur steriles Wasser. Auch braucht man es nicht einen Tag lang trocknen zu lassen. Isopropylalkohol in höheren Konzentrationen verdunstet schnell und verdrängt das Wasser. Das Wichtigste ist hier die Reinigung. Am besten wäre natürlich eine professionelle Reinigung mit einem Ultraschallreiniger. Vergesse nach der Reinigung nicht, die Batterie zu ersetzen. Das ist ein Muss und keine Option. Er wird kaputt gehen, wenn Du dich nicht sofort darum kümmerst. Baue Dein Telefon danach wieder zusammen und bewerte es erneut. Solange es nicht gereinigt ist, ist alles nur eine Vermutung. Möglicherweise ist der LCD-Bildschirm defekt und ein Austausch der Display-Baugruppe kann Abhilfe schaffen. Trotz alledem hat ein Wasserschaden nur eine geringe Chance, vollständig repariert zu werden, aber Du kansst es zumindest versuchen.
War diese Antwort hilfreich?
Wie bekommt man die EMI shields ab?
@annemarie66291 some of them fold up and others need to be desoldered. If none of that works for you, you can always cut them carefully with some trauma shears :-)
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 36
Insgesamt: 802
