Zum Hauptinhalt wechseln
16-Bit-Videospielkonsole des japanischen Unternehmens Sega, die 1990 in Europa veröffentlicht wurde.
37 Fragen Alle anzeigen
Power switch replacement, is it easy?
so i have two Genesis model 1 consoles and one has a very stiff power switch and the other console doesn’t work but the power switch is very easy to slide. So I want to swap the power slide switch but I can’t find any videos about this. However, I’ve seen a photo of one that was removed but the guy that took it off said he broke it and in the photo there was a spring beside the switch. I guess I just want to know if I desolder the switch, is it going to just fall apart on me?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
So I no longer need to worry about swapping the power slider switches, I bought some lithium grease and worked it into the slider switch and now it slides like butter.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
It could be a build up of dirt causing it to be stiff. I’d try cleaning it first. Very old machine so greasy fingers over time could of clogged it up.
Bewertung 2
1 Kommentar:
Yeah I used some contact cleaner and it helped a bit but still too stiff when the case is put together. I’m going to try some lithium grease first (being delivered today) and see if that helps. But if not, I wanna try and swap them.
von
Antwort hinzufügen
Kevin F wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 23
Insgesamt: 520
