Zum Hauptinhalt wechseln
Dieser Casio Wissenschaftstaschenrechner wurde im August 2000 veröffentlicht. Der Modellname ist FX-115MS.
7 Fragen Alle anzeigen
How to replace solar panel window
My calculator wasn’t pictured. It is an Ativa basic calculator. I accidentally broke the solar screen. I opened it up but don’t know how to replace it or what parts to get. Can someone help me? This is my favorite calculator and was given to me as a gift from a mentor so it means a lot.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
what is the specific model? does it still turn on?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I don't know anything specific about your calculator, but I'm betting it can be fixed.
First thing I'd suggest is removing the LCD display in order to get that ribbon cable that stretches over the solar panel out of the way. It would be safest to remove the motherboard, but it's obviously not made to be removed; it looks like it's held on with a single Phillips screw and five plastic welds.
At any rate, once the LCD ribbon cable is out of the way, you'll have to take either a soldering iron or an X-Acto knife and either melt or cut off the melted plastic holding the solar panel in place. Next step is to either unsolder (preferred) or cut the black and red wires going to the panel so it can be removed.
Next problem is to find a replacement. I wouldn't count on finding parts for your specific calculator, although it's not impossible. You should measure the outside dimensions of the panel and do a search for a generic replacement, perhaps something similar to this one, for example.
30x4mm 3.3v 2ua Dim Light Thin Film Amorphous Silicon Solar Cell Ito Glass For Indoor Product,calculator,toy,0-3v Battery - Alternative Energy Generators - AliExpress
Unfortunately, I don't know enough to tell you what voltage output you'll need from the replacement panel; solar technology has come a long way since your calculator was made.
Anyway, once you've found a replacement, you should temporarily hook it up and verify it powers the calculator. If it's all good, then you'll need to remount the panel into the calculator; you can probably resecure it well enough with hot glue. Reinstall the LCD panel and put the rear cover back on and you should be all set!
With any luck it should be a straightforward repair; the hardest part I imagine will be locating a replacement part. I'll be happy to help look for one once we know what size you need; most of the ones will be measured in millimeters, but it's easy enough to convert if you only have a US Standard ruler.
I'm also hoping some of our more knowledgable contributors such as @oldturkey03 and others might have some thoughts on what voltage output to look for; I assume we won't be able to find out from measuring your existing one since it's broken.
Good luck; let us know how it goes and what you find!
War diese Antwort hilfreich?
Bewertung 3
6 Kommentare:
@dadibrokeit do you have a calculator repair shop? I’d like to send it to someone to fix. I am not handy, and don’t have these kinds of tools. If you don’t repair these do you know of any places that do?
von
@tayvataylor I'm afraid not; I'm just a nerd with too much time on my hands who likes to know how everything works.
If you're in the US, what part of the country do you call home? If not, what country are you in? There are a lot of repair technicians who come here who may be able to help depending where you're located.
von
Hello, iFixit staff here! @tayvataylor If you're not comfortable posting where you live publicly, email me at community@ifixit.com and I can help you find your closest repair café to your area.
von
@dadibrokeit I am just seeing this. I am in Alaska but can mail it to you if you’re willing to help me. I just found an exact calculator on eBay so that should help with the replacement parts. I’m willing to pay for your time and return shipping too if you’re still up for a project. This calculator is very sentimental to me and I’ve been missing it so much. Thank you!
von
@amber Hello! I have this broken calculator but I found an exact match on eBay. Do you know anyone I could pay to do this project? I am willing to pay for mailing to/from and for time/experience.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Tayva Taylor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 141
