Zum Hauptinhalt wechseln
Repair guides and support for a wide range of snow blowers.
8 Fragen Alle anzeigen
I can only move foward if I press easy turn and forward handles
I have a two-stage snowblower and it can only move forward if I press the forward handle simultaneously with the easy turn handle right underneath it. Once I stop pressing both of them, I hear a “cling” sound like a spring and the machine stops as should. When I only press the forward handle it doesn’t move. The snowblower was working fine until I played a little with the speed, but soon after this has happened
Edit:
Maker: white outdoor
Model #: 31CM53K2509
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
power ranger do you have a make and model number for your snowblower?
von
Hi yeah it’s a white outdoor 31CM53K2509
von
Einen Kommentar hinzufügen
1 Antwort
Actually I’de like to edit it by saying that it’s only working fine to go forward if I press the easy turn for both wheels. If I release the gas handle then the easy turn one, there’s no cling sound and runs more smoothly.
Still I’de like to understand why the gas handle doesn’t work on itself
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
power ranger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 80
