Zum Hauptinhalt wechseln
The DJI Mini 2 is a small drone that was made in 2020 by DJI. The DJI Mini 2 has 4K/30fps video and 10km 720p/30fps video transmission.
12 Fragen Alle anzeigen
ESC error after only 58 minutes of flight.
I had flown my mini 2 for 58 mins in total. And left it for a month, when I came back from my travels. I had neatly packed it in its bag inside my closet.
I turned on the mini 2 and it gave me an error ESC. Nothing worked, no updates, it clocks out at 80%, no company help, as I bought it in the USA, but live in Europe.
I'm stuck, it's an $800 brick now. Can you help fix it, I'm super girlie and have none of the gadgets on the fixit page!!! Don't know what to do!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Can you download DJI Assistant 2 for Mavic and try and update the drone and controller firmware using this guide? You must do it on a computer running Windows or MacOS Mojave or earlier.
War diese Antwort hilfreich?
Bewertung 2
7 Kommentare:
@thequacker Assitant software doesn't see the plugged-in drone
von
@l_j What OS are you using? And have you tried a few different cables? If you have the one that came with the drone try and use it.
von
Tried 4 cables, and three different batteries. With and without an SD card.
iOS 16.3 for my iPhone, and drone firmware 01.04.0000 and will not update at all. Gets to 80% and errors (for the last 8 months now).
Also, Drone does not show up on drone assistant 2. The RC does however and updates normally.
von
@l_j What OS is the computer with DJI Assistant on? Windows 10/11, macOS Ventura, etc?
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
Layal Jebran wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 15
Insgesamt: 210
