Zum Hauptinhalt wechseln
Das iPhone 12 mini, das am 13. Oktober 2020 angekündigt wurde, ist eine kleinere Version des iPhone 12 von Apple. Es verfügt über ein 5,4 Zoll OLED Display, einen A14 Bionic Prozessor und ein duales Rückkamerasystem.
73 Fragen Alle anzeigen
iPhone 12 mini black screen
i have an iphone 12 mini the screen is black. However when i place it on a wireless charger it gives a charging beep but the screen remain black. What could be the problem? is it the screen or the battery not charging??
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
It probably died and you have to get a new one.
von
thank you. U mean new battery not new phone?
von
New batterys
von
And if that doesn't work you might have to buy a new phone.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@sirneilsirneil try seeing if it will connect to itunes, it could possibly be in dfu mode
War diese Antwort hilfreich?
Bewertung 1
I'm going to disagree with @liljk; there's nothing to indicate a bad battery at this point. The fact that you get a normal reaction when setting it on a wireless charger says that the phone is running. I'd want to do some investigation first, but in situations like you're describing it's generally a screen problem.
First thing to do is try plugging it into a computer and see if it's recognized. If possible, try doing a full restore of the phone's firmware to try and rule out the possibility that it's a software issue rather than hardware.
Worst case in my opinion is you have to replace the screen. Here's the iFixit guide do to that.
iPhone 12 mini Display tauschen
Bewertung 1
Antwort hinzufügen
Sir Neil (Sirneil) wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 164
