Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für Jura J Kaffeeautomaten
23 Fragen Alle anzeigen
My machine refuses to show any signs of powering up
That breakdown was very helpful in getting the machine apart. Thank you for the great wok in creating and posting. The custom tool for the oval headed screws is readily available now and cost about $10 from ebay or similar.
My machine refuses to show any signs of powering up. It’s not the fuse as I can measure 240V AC making it to the PCBs. So suspecting there is something wrong with the power supply PCB or further down the line. No sign of damaged components - either burnt or capacitors that have blown.
So wondering if anyone has any info on the PCBs. I have found quite detailed repair guides for TVs on youtube but so far nothing for J5s.
Update (08/26/21)
@oldturkey03 - thanks for your response and interest. Here’s the PCB images.
They are not easy to get clearly. In some places discoloration that looks like over-heating but it is not that way on the actual PCB.
The closest I’ve found to a circuit diagram of the PIXX-PRD-12 board is on page 4 of this pdf - the one labeled PIXX-PRD-13. It’s not exact however the components (e.g. the diodes and labels) show the same general intent.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Just an update....
Left my machine sitting on the bench for several months, mostly in pieces. Finally the thought of another cup of plunger coffee became too much. so resolved to have the machine repaired. Put it back together to send it off but thought I'd try one last time to power it up. It worked!!
Been working ever since. No frigg'n idea what was different. But sure beats plunger coffee.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Geepers wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 62
Insgesamt: 374
