Zum Hauptinhalt wechseln
A sports car made by Toyota from 1992-1995. It has a 1.5 liter inline 4-cylinder with a 5-speed manual or 4-speed automatic transmission.
5 Fragen Alle anzeigen
Can I replace rear 6 ohm speakers with 4 ohm?
I'm replacing the rear speakers in my car and the factory ones say 6 ohm. However its much easier to find 4 ohm. I'm looking at some cheap ones on amazon rated for 30rms, the original say 15w on the back so I assume that is the rms for the factory ones. Could this damage the radio (still going to be using the factory stereo) or should I be safe? I don't know anything about speakers.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @carsman248
Not a good idea.
There is a risk of hardware damage to the amplifier in the stereo system. Connecting speakers which have a lower impedance than what the amp is rated for, may cause damage to the amp.
At the very least the sound will be distorted.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Then what should I do? Would it be better to use 8 ohm? Or do I have to find some 6 ohm?
von
@carsman248
Find some 6 Ohm speakers.
Using 8 Ohm won't be good either.
It mightn't damage the amp but the sound won't be good.
von
Antwort hinzufügen
Maxwell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 285
