Zum Hauptinhalt wechseln
Repair guides and support for motorcycles manufactured by Harley-Davidson.
77 Fragen Alle anzeigen
My speedometer light works intermittently
On my 2009 stock dyna streetbob the backing light for the speedometer goes out at cruising rpm. When I let off the throttle and go back to idle rpm the light comes back on. This happens consistently. All other lights, the speedometer, odometer and clock are all working correctly.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Have seen a couple different things cause this issue;
1. Bad voltage regulator
2. Wires under rear fender getting worn away by the tire and creating a short
3. Loose battery terminal connection
4. Speedometer might be going out
I'd start with the easy stuff like checking the wires tightening the battery connections/making sure the terminals aren't super corroded and go from there.
Hope this helps!
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thank you Robert H. I'll start there👍
von
Antwort hinzufügen
Jesse Duncalfe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 92
