Zum Hauptinhalt wechseln
Samsungs zehnte Generation ihres Flaggschiff "Phablets" mit S Pen Stylus und 5G-Konnektivität. Veröffentlicht im August 2019.
18 Fragen Alle anzeigen
Overheating Error Glitch with Note 10
It is not actually over heating rather I assume bad sensor somewhere. I have successfully pulled the back off the device but cannot pin point the faulty hardware. Some help would be appreciated, thanks in advance
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi there! This could either be a faulty charging port or a faulty wireless charging coil as both have built-in thermal sensors! It's very unlikely, but if neither of these fix it then it may be a logic board issue. Hope this helps @beefman26 !
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Sorry I didn’t get a notification of your answer. It also doesn’t charge wirelessly. I just tried a new charging coil with no luck. Is there anything else I can try? Thanks
von
@beefman26 Could be the charging port, if i remember correctly there's a thermal sensor on there too! If not, a battery might be another good shot
von
Antwort hinzufügen
Ethan Lewis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 45
Insgesamt: 241
