Zum Hauptinhalt wechseln
Repair and maintenance guide for Bosch 11321EVS, a demolition drill made by Bosch, model number: 11321EVS.
2 Fragen Alle anzeigen
Seems to not be getting power
Green light on side of hammer goes on and off when I wiggle the cord. Cord has no visible damage and each wire in the cord has continuity. The wire connection block for the ground (green wire) seems to wiggle. The brushes on the motor appear to be only 1/2 worn.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
could still be an issue with the cable as you said the light blinks when you wiggle it. cut about 5 inches off the top and rewire it. i have repaired 2 titan sds breakers and the cable was the issue on both
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Ranford Johnson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 156
