How to remove the internal SSD?
The internal SSD is not using the normal SATA connection, I have the backplate off. There are rubber corners around the SSD too.
Update (05/28/23)
. Photo
Ist dies eine gute Frage?
. Photo
You should be able to just slide it out as shown in the attached picture. After you pull it out, you may find that the drive really is a SATA drive, just connected in a wonky connector. I was taking apart a laptop the other day that had a ribbon cable attached to an adapter that attached to a SATA connector on the drive. Just give it a go and let us know how it goes.
Good luck!
War diese Antwort hilfreich?
That works thanks!
You're very welcome! I'm glad my tinkering was able to help someone! :)
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 83
1 Kommentar
I added a photo but I am unsure if it posted.
von SaltyAsterisk
