Zum Hauptinhalt wechseln
Mittelstands Smartphone von Samsung. Gute Leistung für gutes Geld. Modelnummer: SM-A530F
23 Fragen Alle anzeigen
when charging the phone says moisture detected
when i charge my my phone the phone says moisture detected,i don't live in a humid environment and i don't remember dropping my phone on some water,i tried cleaning the usb port but it didn't work. what should i do?
(sorry for my broken english)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@senopatib first try this. Turn your phone off. Then connect the charger. See if it does now charge. if you are sure that there is no moisture in the USB port and if you already cleaned it with isopropyl alcohol etc. it is time to replace the port. Of course, on this phone the port is soldered to the logic board which would require some board level soldering. If this is above your level of comfort, consider getting in touch with somebody who does board level repair. Check https://www.youtube.com/watch?v=0ZjDjt6Y... as well before working on it. This video shows you how to replace the port. It's not as easy as the video makes it seem. It'll take some experience to do the soldering.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Senopati B. wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 302
