Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen zu Googles Pixel 7 Pro Smartphone, erschienen im Oktober 2022. Die Modellnummern sind GP4BC und GE2AE.
97 Fragen Alle anzeigen
After screem replacement microphone only works for calls
After replacing my screen with the iFixit one, i've notticed that my microphone only works for a phone call. Nothing else works, nor google assistant, nor the recorder nor nothing. Top mic seems to work as on the video recording it is the one that is getting the sound
Ist dies eine gute Frage?
Bewertung 8
13 Kommentare
I don't have a solution, but I do have the same issue. seems both microphones are broken for me.
von
Same here!Both microphones dead after replacing the screen
von
:( Same here
von
I have the same issues, replace my screen now mic doesn't work except for calls and some apps.
von
same problem
von
8 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I really don't have the time to pursue this to the next level. But I might just make the time. This is ridiculous that Google is not helping with this problem.
War diese Antwort hilfreich?
Bewertung 1
@lucianobuszmicz This seems to be a common issue with the Pixel 7. I've linked a thread here that you may find helpful. Someone suggests cleaning out the microphone hole with first a vacuum then blowing air into it. It is possible that during the screen replacement process, some finger dirt or perhaps adhesive from the screen got into the microphone.
Bewertung 0
5 Kommentare:
Hi @dannish,
Wouldn't a blocked microphone hole also prevent the microphone from working properly on calls?
The OP says it does work but only on calls, nothing else. Presumably they're not using the phone in speaker mode on calls when saying this
von
@jayeff That's what I thought until I read the thread, apparently certain software on that phone uses both top and bottom mics, some only use 1. So those which rely on 1 mic will be completely unusable, but those which use both still work. It's odd but the solution on there seems popular.
I've experienced OCA getting into a speaker and dulling the sound quite significantly during a phone screen repair myself so it could be possible for mics as well. Mic holes are even smaller than earpiece speaker holes so that could just be it.
von
@dannish
Fair enough.
Cheers
von
I tried this fix but still no luck. It would appear after replacing my screen with an Ifixit OEM screen, my bottom mic no longer works. I was quite careful during the replacement. Is it possible I broke something internally? Everything else seems to function normally except the bottom mic.
von
@johnjanis
Same here.. si frustating.. juste waiting to see if the next software update will fix it
von
Maybe it's when we updated the fingerprint sensor with win10 drivers ?
Bewertung 0
Antwort hinzufügen
Luciano Buszmicz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 119
Insgesamt: 1,009
