Zum Hauptinhalt wechseln
This machine will automatically cook hard, soft, and medium boiled eggs, as well as poached eggs.
2 Fragen Alle anzeigen
Will not turn on
I’ve just purchased a new/old stock unit, but when plugged in and the button is pushed, it does not light and no heat is generated. The unit is fairly simple; where should I begin to troubleshoot? Line cord continuity?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
@clarknovak58364 start opening the unit up (unplug it first) measure the continuity of the power cord. Then check the switch and next check the heating coil. You need an ohmmeter for the heating coil and measure the resistance of it. Let us know what you find out. Use this guide to work on it Oster Designer Egg Cooker and Poacher Disassembly
Post some pictures of your unit if you are stuck, or if you find something that looks odd, That way we can see what you see. Bilder zu einer vorhandenen Frage hinzufügen
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
Oster Designer Egg Cooker and Poacher Bild
Anleitung
Schwierigkeitsgrad:
Leicht
20 minutes
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Clark Novak wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 33
Insgesamt: 124
