How to fix indicators not working
Indicators not working including harzards
Ist dies eine gute Frage?
For both the turn signals and the hazard light not to work it could be a problem with the hazard switch or the flasher unit.
If you can't hear the flasher unit clicking when the turn signal lever or the hazard switch is operated, more than likely the flasher unit is the problem.
Here's a video that may help to show where it's located. I realize it says for a 2001 Sentra but this is the USA model name for a Sunny.
Here's the electrical wiring diagram for the turn/hazard signals that may help if it isn't the relay or the switch
(click on image)
War diese Antwort hilfreich?
Having been working on cars for half a century now, my old school experience tells me that the first thing to try here is the flasher unit marked M42 on the wiring diagram. That's the part that used to go out all the time, although on modern cars you rarely have to replace them any more. All the same, I'd bet on that first before the hazard switch.
Check for any loose connections or maybe its the problem with the bulb..try changing it
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 68
Insgesamt: 341
2 Kommentare
Hi @dandaniel29708,
What is the year model of the vehicle?
von jayeff
2001
B15 nissan sunny
von Dan Daniel
