Zum Hauptinhalt wechseln
The Toshiba Satellite L300 was a notebook designed and sold by Toshiba that came with a version of Windows Vista. They were sold around May-June 2009 and while ineligible for the free 7 upgrade, time past and upgrades are unclaimable now, run 7 home premium well without upgrades mainly because of Vista's resource hog quality. Also known as Toshiba Satellite L300-04P (PSLB8C-04P01X).
30 Fragen Alle anzeigen
My laptop is not working after long time (6 years) of not using?
I'm not using my laptop for around 6 years (was working before) now when trying to start up not working but charging light is working as before?
What I have to check and what problem could be?
I have to laptop satellite L300 & A300.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi Haitham,
I'd say the first thing you need to do is get a new battery. Lithium Ion batteries don't have a six year shelf life, so if it's been sitting that long I doubt very much the battery is usable in any sense. It sounds like the charger is probably still working, but the battery isn't taking the charge, which is not surprising after all that time.
You could try removing the battery and plugging it into the AC adapter. It may or may not work; it's not necessarily a bad sign if it doesn't, but if it does that would indicate the laptop is functional and a new battery is probably all it needs. Of course, try leaving the charger on overnight; it may be so depleted that it will take a very long time to even start charging if it does at all.
But if you don't see any sign of life after leaving it to charge overnight, then I'd say the next step is a new battery.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Haitham Amer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 30
